Final selection of 408 build parts
#27
Anyway....I changed a few things and got everything ordered today. Pistons are custom, so that may take 2-3 weeks, so hopefully I'll be up and running in a month or so.
Crank Callies DragonSlayer
Main studs ARP
Rods Compstar
Rod bolts ARP 2000
Pistons Diamond 11576 (in-bore -28cc dish - custom cut for 1/16, 1/16, 3/16 rings
Piston rings Total Seal MS3690-35
Oil pump Melling stock replacement
Timing chain LS2 timing set
Cam bolts ARP
Camshaft Vinci Trucker (already have this one - temporary till FI)
Lifters SDPC LS2/LS7 style
Pushrods Hardened
Rocker Arms stock
Valve springs dual
Retainers titanium
Valves Stainless
Heads WCCH stage 2 317's (74cc)
Head gaskets Cometic .03
Head bolts ARP studs (make sure I get 12 point)
Intake manifold SSR manifold
Fuel injectors 42#'ers
Crank balancer bolt ARP
Main studs ARP
Rods Compstar
Rod bolts ARP 2000
Cam bolts ARP
Pushrods Hardened
Rocker Arms stock
Valve springs dual
Retainers titanium
Valves Stainless
#29
Yep I got almost all of the parts, still waiting on a few minor things, but I took the block and rotating assy to the machine shop last Friday. If all goes well I will have an assembled short block back in my possession by this Friday. Of not, middle of next week.
If I get it back on Friday I should be back up and running this weekend, barring any show-stopping problems
This is the thread I have been updating. I'll make a new one once I start getting things back and assembled.
https://www.performancetrucks.net/fo...d.php?t=380102
