Final selection of 408 build parts
Old 11-20-2006, 10:51 PM
  #21
Destroyer of Transmissions
1SlowHoe's Avatar
I dont think the forged crank is required but if it makes you feel better, ok.
Upgrade the lifters as mentioned
Spring for the 96# injectors now or buy them when you go FI.
Oil pan gasket
Hurry up!
Old 11-21-2006, 10:33 AM
  #22
TigerFan187's Avatar
What power adder are you going with? Turbo? Im waiting on my 408 to be built right now. Im just gonna run HC NA for a couple years then put a D1SC on.
Old 11-21-2006, 11:36 AM
  #23
High on diesel fumes
thunder550's Avatar
Turbo. That's the plan for me too, build the 408 now and go turbo when I can afford to.
Old 11-21-2006, 12:17 PM
  #24
thunder550's Avatar
Intake manifolds - I am going to stick with a stock one - trying to decide between LS6, LS2, and SSR. Thoughts?
Old 11-21-2006, 08:55 PM
  #25
ap2002's Avatar
you mind asking how much will the 408 conversion set you back at???
pm me if you dont want to post up..
Old 11-22-2006, 11:24 AM
  #26
thunder550's Avatar
Hmmm looks like my pricing post got deleted. Not sure why? Mods - if the one who deleted it can PM me with a reason just so I understand that would be great. ap2002 - I'll PM it to you.
Old 11-22-2006, 11:29 AM
  #27
thunder550's Avatar
Anyway....I changed a few things and got everything ordered today. Pistons are custom, so that may take 2-3 weeks, so hopefully I'll be up and running in a month or so.
Crank Callies DragonSlayer
Main studs ARP
Rods Compstar
Rod bolts ARP 2000
Pistons Diamond 11576 (in-bore -28cc dish - custom cut for 1/16, 1/16, 3/16 rings
Piston rings Total Seal MS3690-35
Oil pump Melling stock replacement
Timing chain LS2 timing set
Cam bolts ARP
Camshaft Vinci Trucker (already have this one - temporary till FI)
Lifters SDPC LS2/LS7 style
Pushrods Hardened
Rocker Arms stock
Valve springs dual
Retainers titanium
Valves Stainless
Heads WCCH stage 2 317's (74cc)
Head gaskets Cometic .03
Head bolts ARP studs (make sure I get 12 point)
Intake manifold SSR manifold
Fuel injectors 42#'ers
Crank balancer bolt ARP
Old 12-13-2006, 05:06 PM
  #28
Tootall's Avatar
where are you at on this? any new pics ?
Old 12-13-2006, 05:23 PM
  #29
thunder550's Avatar
Yep I got almost all of the parts, still waiting on a few minor things, but I took the block and rotating assy to the machine shop last Friday. If all goes well I will have an assembled short block back in my possession by this Friday. Of not, middle of next week.
If I get it back on Friday I should be back up and running this weekend, barring any show-stopping problems
This is the thread I have been updating. I'll make a new one once I start getting things back and assembled.
https://www.performancetrucks.net/fo...d.php?t=380102
thunder550
10-08-2015 04:53 PM
USMCvet0311
08-14-2015 10:28 PM
mrhino
08-07-2015 10:01 AM
gafool
07-28-2015 05:20 PM
Cowboy17
07-09-2015 06:18 PM
Quick Reply: Final selection of 408 build parts
