Finally went to the track...
2nd fastest 5.3 ECSB
that's only a 10% difference in gear ratio. I run 30.5" tires too. What was your approximate HP at that time? I'm making decent torque (564) at very low rpm and haven't yet had any traction issues while in 4wd on dry road. Wet, no problem. Damp, no problem, but dry, no way.
What is your current setup? Are you RC?
MID LS1 block 4.125" bore
Callies 4" crank
Diamond -7cc pistons
Oliver Rods
AFR 225's w/ Comp 921's
Jessel adj. rockers
Morel lifters
Tony Mamo ported Fast 90
LG G5XX cam
Dynatech Headers w/ custom 3" collectors
3" true duals w/ X-pipe
FLT/FLP level 5 4L65E
4.10 w/ Eaton posi and rear end girdle
42# injectors w/ in-tank walbro 255
Callies 4" crank
Oliver Rods
Jessel adj. rockers
Morel lifters
LG G5XX cam
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
