Finished the Fast 90/90
Old 03-02-2008, 06:29 PM
built408's Avatar
Default Finished the Fast 90/90
Well I finally finished the fast 90/90 setup... Just had to show it off some.. Getting tuned this week, can't wait for the results...
Old 03-02-2008, 06:35 PM
Mort's Avatar
That sure looks nice. Good luck on the numbers.
Old 03-02-2008, 06:41 PM
ZR1 DREAMING's Avatar
Are you running an electric water pump? Do you have any head on shots of the accessory drive, WP, and TB position?
Looks good man.
Old 03-02-2008, 06:49 PM
built408's Avatar
Yes I'm running an electric water pump... I dont have any pics right now but I can take some. I came up with my own way to relocate the idler puller. I just used a c6 corvette idler pulley (alittle smaller) spaced out and mounted to the existing mounting bolt right under the alternator... Had to order a 6inch long 10mm bolt to mount it tho. And used a longer belt. Worked out pretty good...
Old 03-02-2008, 07:56 PM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
Looks great can't wait to see some #s
Old 03-03-2008, 10:53 AM
built408's Avatar
Thanks
Old 03-03-2008, 11:05 AM
TXsilverado's Avatar
hey, can you post a picture of the pully method you used? how much did everything cost in the end?
Old 03-03-2008, 11:25 AM
dkota1968's Avatar
That looks bad *** man, good job. id also be interested in those pics.
Old 03-03-2008, 11:26 AM
Llaverito's Avatar
Something like this except this is the same truck pulley
Old 03-03-2008, 12:39 PM
KISS method FTW!
that looks alot easier and cheaper than the relocation kit. what grade bolt is that?
Quick Reply: Finished the Fast 90/90
