flex fuel
flex fuel
i was gonna buy this 07 silverado classic, 5.3 extended cab, 2wd but then noticed that the engine was the L59. which is the 5.3 flex fuel. whats the difference between this engine and the LM7 5.3? is it just a sensor and an extra computer that allows it to run the alternative fuel? i plan to put heads/cam on the truck. would i be better off with finding one with the regular 5.3?
well i plan to only run unleaded gas. while running regular gas is there any difference between the two engines? power, mileage, sound? if only the fuel system is different, then does that mean the long block and intakes are the same? so head/cam any other bolt on will work?
My tahoe is flex fuel. No other real differences. Main parts are the same. It has larger injectors, larger coil packs, and the ability to sense ethanol in the fuel system and adjust the fueling accordingly. As far as power output and modability of the truck, it should be virtually identical.
My new 06 is flex fuel... i would recomend it just incase something on down the road happens to gas and prices go to $10 a gallon and ethanol stays 2.50... i wish but doubt it but anyway got with the flex fuel
some of the non flex fuels are rated at 310 hp vs the 295hp. One is an iron block, one is aluminum...i forget which is which but i think all flex fuels are 295hp...tq is the same though
GXPJAY
01-27-2016 11:45 AM
lxcoupe
17
08-26-2015 05:00 PM
05GMC4.8
08-07-2015 09:55 PM
Closer_2001
07-21-2015 03:25 PM
