flex fuel vs. non
Old 02-24-2007, 05:18 PM
Un-Registered User
mcfarlnd's Avatar
Default flex fuel vs. non
what additional stuff is on the flex fuel models???? is the motor the same???? injectors and stuff???? thanks.
Old 02-24-2007, 05:21 PM
joshluther's Avatar
Injectors and rails are different and I heard that the seals are different in the fuel system. The motors are the same.
Old 02-24-2007, 05:24 PM
Blown02Sierra's Avatar
AFAIK there's some sort of system to determine the ratio of ethanol to gasoline to alter the air/fuel ratio to run stoich w/ the mixture. I dont know if they do or not, but they should, also increase timing depending on the amount of ethanol. Also, different materials in the fuel system that the alcohol wont destroy.
Old 02-24-2007, 07:27 PM
Un-Registered User
mcfarlnd's Avatar
so is it a bad thing to have a flex fuel???
Old 02-24-2007, 09:36 PM
TURBHOE's Avatar
no you get bigger injectors stock and i think maybe bigger fuel pump to because the ethonal take a richer mixture than gas. plus you can run more boost with the other fuel it has higher octane
Old 02-24-2007, 09:37 PM
TURBHOE's Avatar
no you get bigger injectors stock and i think maybe bigger fuel pump to because the ethonal take a richer mixture than gas. plus you can run more boost with the other fuel it has higher octane IF I Had a choice i would have got flex fuel
Old 02-25-2007, 11:58 AM
Un-Registered User
mcfarlnd's Avatar
right on. thanks guys. mike fix your phone, ive been trying to get ahold of you for a week.
Old 02-25-2007, 01:48 PM
11 Second Club
Phantom's Avatar
my gas cap is different too
Old 02-25-2007, 05:48 PM
Un-Registered User
mcfarlnd's Avatar
lxcoupe
17
08-26-2015 05:00 PM
05GMC4.8
08-07-2015 09:55 PM
RS/SS 4.8
08-02-2015 11:03 PM
Closer_2001
07-21-2015 03:25 PM
Quick Reply: flex fuel vs. non
