flow rate of 8.1 injectors
LOL....I had this post all worked out for the marine injectors, actually Multec II Shorty injectors when I realized you wanted it for the truck 8.1 injectors.
I am not really sure, but if my memory has not failed me again, they are rated near 33 lb/hr. LOL...don't take this as gospel.
Straight from Delphi's catalog for a 2002 8.1L: http://go.delphi.com/esp.asp?sess=DCM56NZ7MZRA6HYP90YM
30 lb/hr @ 43.5psi
Now all you have to do is determine the flow @ 58 psi.
30 lb/hr @ 43.5psi
Originally Posted by GMC_DUDE
Are these the same ones used in the Radix kit? If so, my HPTuners says the PCM is programmed for 41.667 lb./hr.
30 lb/hr @ 43.5psi
30 lb/hr @ 43.5psi
this is what I get
Injector Rated Fuel Pressure: 43.5
Your Fuel Rail Pressure: 58
Injector Rated Flow Rate 30
Injector Flow (lb/hr) 34.64162706 34.85752419 35.07209232 35.2853557 35.49733784 35.70806157 35.91754903 36.12582173 36.33290055 36.5388058 36.74355721 36.94717396 37.14967471 37.3510776 37.55140031 37.75066003 37.9488735
only problem is its scaled guess Ill use the 34.64 value across the board
for those who would like to know the 8.1L injectors flow 40lb/hr at 58 psi the 30lb/hr is at 300 kpa which delphi rates them that way to match the fuel rail pressure of the 8.1 rails, the 5.3 injectors are rated at 25lb/hr at 58 or 400 kpa. The reason delphi did this again is the differences in the systems they are used on this is where I was getting confused.
delphi part number fj10494 for 8.1 fj10062 for 5.3
Called up delphi and talked to them they have great customer support
was also told that I need to watch what type of drivers the pcm is using there are two types hopefully someone will jump in.
Is there a difference between the 5.3 pcm injector drivers and the 8.1 pcm injector drivers?
Also some interesting info is that all injectors including other manufacturers are designed to only operate at a max of 80% this is why I hadnt melted the stock 5.3's running them at 120% duty cycle.
now Ive got more tuning to do
