FLP tranny durability
Originally Posted by chris99gmc
Why are you steering away from the 80e?? all in all, you might even spend less on one in the end.
They are straight tanks out of the junk yard, and can easily take 1000 rwhp without breathing.
Goshawk- I checked with slow and spoke with Bernard at Team Tripp. He recommends a no larger than a 10" converter with his tranny's. Mine's like 11" so he's not sure about warranty.
I pulled the pan down yesterday just to look and it wasn't in great shape. The fluid wasn't red it was more of a dark maroon. The magnet was covered with very fine metal and there was also tiny shavings laying in the bottom of the pan. The pan was lined with "black dust" that would come off by wiping my finger across it. I think it's on it's way out. I've decided to pull it out now and install.....built 60, 65, FLP
I have a couple of friends that run ext. cabs with modded 6.0's with built 60e's and been holding up pretty good. one of them runs like 12.6x's. Don't know how long that will last though. I thinking I'll either get a 65 built or have Chuck fix me up.
I think you would be safe with either of the two 4l60es. I've heard good things from both flp and team tripp(I love mine!). Mine hasn't so much as hiccuped yet, and I've been pushing it pretty hard. Good luck on your decision, and hope the stock one doesn't leave you stranded anywhere.
11 Second Truck Club
I just installed a level 5 in mine and waiting till I get 500 miles to nail it but I shifts great alot better than my built 65e. Just riding around b/f when it shifted it would throw you back in the seat and now just cruising around it shifts hard but not so extreme. My wife even says it shifts so that she would drive it again.
the previous trans shifted harder than the level V?
Then that would tell me to get the 4l65 lv 4-5 so you dont have to worry about it later, of course if you werent planning on going much further than you are now, then screw it 4l60 it up and take it as far as it will go. But if you plan on runnin low 11's or 10's id suugest stepping into the FLP 4l65e Lv4-5 upgrade!!
