flywheel question
High on diesel fumes
Originally Posted by Quik
60Es dont use flywheels
if you mean using the ls1 flexplate its the same
Flywheel = manual trans
Flexplate = auto trans
But yeah, the flexplate is dependent on the tranny, not the engine. If you don't change your tranny, you shouldn't have to change the flexplate. The only one that would be different would be if you were using an early 6.0 with the longer crankshaft.
carid
09-10-2015 09:07 AM
