Ford Racing 42lb Injectors for 5.3 Chevy
Adkoonerstrator
Originally Posted by kbracing96
But those are for a flex fuel harness, right 1SlowHoe? They are different from a regular truck harness.
TurboAV - Here is a writeup I did on how to convert over to bosch style injector(Ford SVO 42# included). It's not hard but, it is kinda time consuming. Once you switch over to this style injector your choice for injectors opens up a ton.
http://hauln.net/LS1Tech/truck/fuel_injector/index.html
Originally Posted by 1SlowHoe
CoonToot--You got the part number for the connecters?
Summit Catalog Page
Destroyer of Transmissions
That adapter does fit my flex fuel clip BUT it was designed for Corvettes if I remember right. It just happened to fit my clip as well. I have not seen a vette clip to verify they are the same. Those are locally manufactured at a shop close by me. I bet if you guys could find me the part number to your clips, the guy could make adapters to go from standard LS1/Truck clips to the Ford injectors. I can at least ask. Anybody actually want some?
Adkoonerstrator
Tribe Shaman
I have had MANY issues with my stock clips coming loose and causing misfires. If these adapters don't work flawlessly, I'm cutting the wires and grabbing a solder gun. I'll let you know after I get it running
get the gun out and burn away, i did and feel better about the connection,
it is more solid now then it was before.
