forged 6.0 or 370
what would be better as far as dd and gas mileage itll be going in a crew cab truck witha front mount turbo with 8-10lbs boost..top end will be a ls6 cam with wcch stage 2 317 heads i already have the heads and cam but undecided on the block..need help
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
maybe your talking about a 408?(4" stroker crank in a 6.0 block)
no i meant going 370 i plan to pick up a 6.0 block and bore it out to a 370 but was curious how would this combo work
370 block with mahle pistons
stock 6.0 crank
stage 2 wcch 317 heads
ls6 cam, ls7 lifter, 7.4 rods
front mount turbo
60lb injectors
is this a good combo anything u guys recommended
stock 6.0 crank
front mount turbo
60lb injectors
right ill be boring out the block to make it a 370.
does anyone have part number to all the gaskets ill be needing or are there different part numbers..
only gasket i bought new was some cometic .040 head gaskets.. every one will tell you to buy front and rear cover gaskets, water pump gaskets.. jfyi when my 370 runs i DD it, and its gotta big ole healthy cam and 4.56s.. one thing thats daily driver friendly to one person may not to another.. once i finally got mine tuned it was a blast to drive around..
lukn4trbl355
10-21-2015 11:19 PM
GMCtrk
18
10-06-2015 03:48 PM
