Forged LQ9 pistons, stock compression ratio
Originally Posted by j4nash
i know the radix can't make 15psi of boost , but what i said is for me that is what i would do because i have a procharger
![Rolleyes](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/rolleyes.gif)
but after that you can gain some with a good set of stage 3 heads. but at the same time if you are going to build your motor up, atlest go with a dished piston and better rods. it will help you out in the long run
Originally Posted by gamedawgx53
how well are the ss guys doing with the radix?
how will the new heads affect your CR?
looks like you got a lot of research to find that optimum CR
to match your setup
to match your setup
ARC
57
02-21-2022 10:54 AM
