Found my high temperature problem
Old 07-22-2004 | 06:18 PM
ThunderZ28's Avatar
12 Second Club
Default Found my high temperature problem
Well as some of you know I had been running kinda warm on the motor and trans here lately, and couldnt figure it out. thought maybe my thermostat was going bad, or the water pump was, so I replaced the water pump, last week, and lo and behold, it overheasts on me again today 250* by the crappy stock gauge. and my Autometer trans gauge was at 240*
well I get it to cool down, to do this I parked it , and then unhooked the electric fans,from the VSC to have them run all the time while the truck is off.
well after a brief period of letting the motor cool, I got in it and began to drive it. temps are now back down to 180* and the trans is at 150*.
and get this they stay there!
Even in stop and go traffic the motor and trans never got above 190* @ 98* outside.
So with this little observation. I have come to the conclusion, along with a few others, that the VSC from Flex-crap sucks the big one. I even had the 40Amp, one and it was letting my truck over heat!
so there, I am running the fans manually now, untill I get one of those harnesses to run the fans off the PCM.
Old 07-22-2004 | 06:29 PM
shandy294's Avatar
What's Flex-crap's real name so I can beware?
Old 07-22-2004 | 06:32 PM
hink9's Avatar
flex-a-lite
Old 07-22-2004 | 06:55 PM
99Silver6.0's Avatar
Man, those temps were getting up there. Good thing you found the source. I have some LS1 fans I need to put in. Im gonna run one of Allens fan harnesses too.
Old 07-22-2004 | 10:14 PM
someones gotta talk him into a group purchase for the fan harnesses
Old 07-22-2004 | 10:26 PM
storm5.3's Avatar
13 Second Truck Club
YIKES!!!! Jesus man!!! I would've flipped out if I seen my temps that high, good thing you looked down...Zed
Old 07-22-2004 | 10:29 PM
Flyer's Avatar
Ya know ... now that I think about it .. mine was running a little warm when I was dragging the boat around a while back ... a LONG while back. I was thinking that I couldn't hardly hear the fans running. I know I need to do something about it now.
Good info there Thunder.
Old 07-22-2004 | 11:41 PM
bigguy75inches's Avatar
im in the same boat here too. according to my stock gauge. i usually run around 175 on the temps with 292s and a 160 stat. sometimes i notice it works fine, and others i notice it creeps up to aorund 210. it pisses me off cuz it didnt use to do that. i also found out that with the ignition on, and i turn my ac on, the fans no longer turn on like they did awhile back. im on my second controller thus far.
Old 07-23-2004 | 12:19 AM
Ryan23silverado's Avatar
250 can start warping the heads. Just pin it to blue42 on the pcm if you have edit. It works well.
Old 07-23-2004 | 12:23 AM
ThunderZ28's Avatar
12 Second Club
yeah I am hoping I didnt hurt anything. guess I will be finding out here shortly
Quick Reply: Found my high temperature problem
