Found my high temperature problem
I've had my temps go that high numerous times because of the flex fans. Once when the fuse holder melted, several times when the VSC stopped working, once when a motor burned up all the wiring... Not fun. I called FAL and they send out a new VSC, fan motor, and all new wiring. So far so good.
I'm back to running the VSC, but this time, I have the PCM tripping the manual on / off terminal on the VSC instead of the temp probe.
Originally Posted by Ryan23silverado
250 can start warping the heads. Just pin it to blue42 on the pcm if you have edit. It works well.
Thats what I did. I wired the PCM to trip the Manual negative ON pin. It comes on 100% when that temp is reached. I think I may go ahead and add the temp probe set to a lower temp then they will start at slower speed earlier and hit 100% via the PCM at 200* (where I have it set).
Only I set my PCM to turn them on at 185...
How long have you guys been playing this game? Yes, the vsc is inexpensive, but do a site search and find out what the failure rate is. Maybe 70%? How much is your time, the cost of sweating bullets every time you sit in traffic and the risk of engine damage worth? Yes, they replace them for free, but is there any real bargain in that?
Then do a search on this and the mustang sites for the dccontrol unit. How many failures do you see? Zero. It's $30 more than the vsc, but considering the difference in reliability, it's much less expensive than the real cost of a free replacement vsc.
www.dccontrol.com
www.dccontrol.com
Corvette454l88
09-01-2016 01:24 AM
GMCtrk
38
08-09-2015 08:50 PM
hartinclay
08-03-2015 07:03 PM
grantpo
07-15-2015 12:21 PM
