Free Performance Mods
Originally Posted by TIM Z
what size coupling do you guys use for the TB bypass?-Thanks
Originally Posted by skinnyVHO
are yall capping the barbs on the throttle body when you bypass it?
Originally Posted by EvilTwin
YES with Vacume caps and De-screening the MAF Helped me a lot i just have to make sure the K&N isn't over oiled.. IF you do DE-screen just keet a can of electrical contact cleaner handy all the time
Originally Posted by stone150
what does thaat mean?
also how much coolant comes out then you do the bypass?
http://www.geocities.com/wilwaxu/throttlebody.html
i used vice grips to pinch both sides of the coolant lines to prevent any major losses of coolant
most people with te TB mods spend quite a bit of time porting it all so alot of times the gains are all in their head. if you do the bypass, you shouldnt lose much if any coolant as long as your engine is cold. if you live somewhere its very cold i do not recommend doing the bypass at all or in the winter your TB could freeze
