freeking valvetrain noise!!
Old 04-18-2008, 12:12 PM
brodystruck's Avatar
I had the same thing going on with Patriot dual springs. I checked the rocker torque about 5 times before I quit being paranoid. I know you don't have the same springs as I do though...
Old 04-18-2008, 12:59 PM
LMSeven's Avatar
I have the same cam and springs, it's normal. I can't hear it when driving, but when I pop the hood and it's running it's a sewing machine.
Old 04-18-2008, 01:16 PM
sickREDsierra's Avatar
i appreciate all the response guys... i didnt think that setting the valve lash was reall possible on these gen iii's..... i used to set them like that on my old nova, but it was a flat tappet cam with adjustable rockers and poly/locks...
i guess i will just have to live with it.. i have put quite a few miles on it since the cam, maybe 10K or so, it still sounds the same... i was just hoping there might be an easy fix... like spitting on it or something... that usually works with everything else.
it was such a pain in my *** changing those springs, i will just leave em alone..
i wonder if i threw some fabric in there, would it sew it up for me??
Old 04-18-2008, 01:57 PM
Gator's Avatar
Your right you can't adjust valve-lash... you can just change the preload by either using shims or different PR lengths
Old 04-18-2008, 05:42 PM
Okie5.3's Avatar
also a note when shimming or changing the PR length, be sure to check the swipe the rocker leaves on the valve tip falls in the center as much as you can.
Old 04-19-2008, 05:38 PM
SincalT/A's Avatar
I am running the same cam in a Whippled 4.8.It sounds basically stock other than a little lope.The only difference in our set up(as far as valvetrain is concerned) is I have stock pushrods.
Old 04-20-2008, 12:13 PM
My truck sounds normal with the 210/218 and ls6 yellow's...
only thing i don't like is my truck gets the shakes for 15-20 seconds after i start it up.
Old 04-21-2008, 10:16 AM
zapata41's Avatar
i also have noisy valve train after cam swap, behive spring and comp cams pushrods, i used to be real worried about it but that was close to 10k ago, now i just romp on her and not worry, does play havok with my knock sensor though
Old 04-21-2008, 01:37 PM
custom 68's Avatar
just get a loader exhaust or a cutout and you wont hear the sewing machine sound...
JK anyway I would think with the ls6 springs you woule still be quite, I bet Gator is right you need longer PR.
Dave
Old 04-22-2008, 02:27 PM
02burban's Avatar
Is The Sewing Machine Sound With All The Comp-cams... What Does It Take To Shime The Rockes...
Quick Reply: freeking valvetrain noise!!
