fuel pressure gage
fuel pressure gage
i am about to install a permanent FP gage under the hood, connected to the schrader valve.
just curious if anyone has any pics of this install ... wanted to see how tidy i could make it, and not have hood clearance issues as far as what position i put the gage in.
also, are there any good hard fitting kits for this install floating around, other than a regular pressure testing kit? i am just looking for a 0-100 psi analog gage and fittings to cleanly hook it up where i can see the gage outside of the engine cover.
thanks for any input
1 Post
i ordered this from summit to tap into the rail......Caspers Electronics 102071
its a tee fitting that allows you to run a gauge and still have a bleed valve.
it would take a few fittings but im sure it would be easy to route the fittings to be out from under the cover so a gauge would be visible.
Mossyoakglock
08-28-2015 12:49 PM
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
