Fuel Pressure Gauge....
single digit dreamer
Re: Fuel Pressure Gauge....
is your kit wet or dry? if you try to run larger than a 125shot with a wet kit i would have one. it should read around 58psi at wot but will drop a little at idle. you would be watching for it to dip at the top of each gear, if the presure falls during a wot blast it only takes a second for it to go lean and break a piston.
If your N2O kit is worth its salt it will have a fuel pressure shut off. If the fuel pressure is too low the N2O wont engage. If your kit does not have one they are cheap and easy to add.
Mossyoakglock
08-28-2015 12:49 PM
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
