Fuel pressure low...
At idle my fuel pressure is 44 and only 52 at wot. Walbro 255 in tank is brand new. What can I do to get it back where I need it?
If you have a gauge to put on the fuel rail you can disconnect the vacuume hose on the top of the fuel pressure regulator and the pressure should go up to 70 ish. Then you know it is the regulator that it bringing it down to the level its at. Also, the regulator could be leaking if the vacuume hose is wet although this normally will make it flood a little not drop pressure.
Mossyoakglock
08-28-2015 12:49 PM
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
