fuel pressure questions
1 Post
ok i just got my autometer fuel pressure gauge in and i finished wiring it up earlier and i noticed that while idleing and cruising pressure stays at 55-58psi, but then WOT it falls to 40psi. I know its not supposed to be that low. I have a walbro intank so i shouldnt be having a pressure problem unless its my filter witch is fairly new but im going to change tommorow anyway. Could it be my regulator?
i need to fix it before sunday so i can get my dyno tune done.
any clues?
right now im going to start with filter, if that dont work, regulator, if that dont work im going to pull the pump and check the line inside the tank.
Thanks,
Caleb
any clues?
Thanks,
Caleb
Test the electrical connections at the sending unit. They may not be secure and are causing a constant supply problem which is making the voltage drop & reading lower while under load.
Have you contacted support at Autometer? They are very fast in responding & can give you the proper test procedures. I think it's best to go that route before dropping the tank & checking the lines/pump.
1 Post
yea i planed on getting a hotwire kit, but upgrade the pump.....shouldnt my walbro 255 support my mods?
im really hoping its the filter cause i dont think ill have time to pull the tank and check the hose before sunday.....i may just drop it off at a friends shop in the mornin for him to take a look. maybe its the regulator??
1 Post
i have a mechanical gauge i can test with i just cant see it while driving if its under the hood
1 Post
i changed my filter and took my pump out and replaced the stock feed hose with a high pressure goodyear ruber line with the blue nylon liner or something and i got pressure back.
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
