fuel pump setup R U running
I am losing fuel pressure on 1 out of 5 WOT runs causing a real bad lean spike. It's only a spike cuz I let off the gas as soon as that WB leaves the 11.5 area....it makes it to 17:1 for a split second.
The pump is my second stock pump. I have now the Magnacharger inline booster and the stock regulator. I know some of you run the walbro 255 in tank, but is that with the bucket? Does anybody make the direct replacement for truck's tanks yet? I know I shopped it last year (before I got the second stocker)and you had to either modify your bucket or just go bucketless.
I'd love a plug and play with bucket...but I have a feeling I will still need to modify it to get those results. Any help on some product I am missing out on? The stocker is a MU1089 setup...last year racetronix couldn't help me.
So you have an inline booster pump and the 43lb marine injectors and you are getting a lean spike sometimes?? I hope Im not having the same issue. Is this common? Is this why you replaced the last pump? The only thing Ive heard of is a single or dual intank walbro.
Originally Posted by dewmanshu
I've been dealing with inconsistent fuel pressure since my first radix mod June of 2004 on the 5.3. Inconsistent meaning anywhere from 40psi to 56psi at idle or driving with no throttle (coasting at any speed). Sometimes it stays stable at 55-57psi, but most of the time it's all over the place until you hit the gas, then it goes up. And about 80% of the time at WOT it's fine, hell it's like 66psi. But then like 20% of the time the pressure will slip down and of course I am not watching it, I am watching the WB/AFR. I am clueless on this. I don't hear of this problem with anyone else or I would jump all over that thread. I am plain desperate here on this one. I have read the recent threads about this, but it doesn't quiet explain my issues. Actually confuses it more. I just don't know if a higher volume pump in the tank would make this go away.
Originally Posted by DrX
Could be the regulator/regulator install(o-ring issue??). Sounds like the pump is putting out the pressure.
5.3lSilverado
25
08-29-2016 12:48 AM
InsaneDomestics
07-27-2015 02:42 PM
Mossyoakglock
07-17-2015 08:30 AM
