Fuel Tank Builds Pressure after 5 or 10 miles
I have a co-worker that has a 2001 Chevy Silverado 4.8 engine. The gas tank builds pressure after driving 5 or 10 miles or less?
He has changed the fuel pump, filter, three gas caps, e-vap canister, and cleaned the fuel line from the canister to the tank. When removing the gas cap it release a lot of air?
He also has talked with a mechanic and our county fleet guy. Any ideas whats happening here?
GM Has a retro fit for the EVAP Purge solenoid, its relocates it forward and higher out of the way of junk. With a good scan tool you can manually open and close purge valve. I would start with that, bet its stuck closes.
Usually purge vlave is located at rear of tank of side, but thye like to move them around
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
