Fueling Upgrade
Old 05-27-2007, 03:46 PM
DrX
DrX's Avatar
Originally Posted by kbracing96
You can't put inline fuel pumps on a returnless fuel system
BAP, should help the magie pump feed 60's just fine I would think.
Haven't heard much about this: http://aeromotiveinc.com/pdetail.php?prod=32
Old 05-27-2007, 05:38 PM
Stoichiometric's Avatar
Bill, the Radix kits come with a 255 pump fwiw. If you bought one more 255, it is possible to fit them both in the tank with modification. I don't have experience with twin pumps or BAP, don't know which is better. What do you have your Alky kit set to?
Old 05-27-2007, 05:42 PM
2004SSS's Avatar
a dual intank 255 set up will outflow a single 255 with a bap. i had the single with a bap and it still couldnt keep up. i was dropping from 59 to 52 psi . i dont know if it was the feed line size or the pump or a combo of both but my new setup should provide the fuel i need not to mention the methanol injection.
Old 05-27-2007, 05:56 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
So another pump and hobbs switch is a better way to go?
Old 05-27-2007, 06:06 PM
what a rush!
moregrip's Avatar
yes and no, there are + & - to both. The twins will move more fuel but you'll have to keep your more fuel in your tank at any given time since they won't have a basket anymore, however many people live with that minor issue
2004SSS's Avatar
id say so. but i also went to a return system
Old 05-27-2007, 06:39 PM
what a rush!
moregrip's Avatar
this vid has some intank fueling ideas for you!
http://www.youtube.com/watch?v=vyshW...elated&search=
Old 05-27-2007, 08:08 PM
what a rush!
moregrip's Avatar
another option:
Old 05-27-2007, 08:44 PM
LMAO! Does that thing fit in the tank somewhere?
Old 05-27-2007, 09:18 PM
what a rush!
moregrip's Avatar
on a serious note:
right now I'm a big fan of the surge tank setup for us 04 and up guys. We keep our stock fuel bucket with the upgraded Walbro fuel pump. That feeds a 1 gallon-ish surge tank. From there we run dual(or a single) fuel pumps to an engine mounted fuel pressure regulator with a return fuel line to the surge tank. Lastly, a return line from the surge tank to the main fuel tank.
something very similar to this, except instead of a factory in-line pump we would use our existing in-tank mounted pump:
some cool pics of surge tank setups:
Quick Reply: Fueling Upgrade
