G-tech times
G-tech times
This morning I ran a 14.77 at 95.89MPH on the G-tech. It felt stronger then it usually does, but my best before today was a 15.074 at 93.43 and 60ft of 2.365, so I don't know maybe it was a glitch.
I did the run with a cold engine, about 1 minute after startup, and it was only 0-1 degrees C out. I just stood on the gas off the line in 2wd (not even a chirp from the BFG AT KO's )
I did a second run after driving for 20 minutes, 15.164 at 91.56mph
G-tech run rpm and tq vs rpm
G-tech speed
G-tech HP vs time
G-tech Gs
I still need a little more tuning done, the LTFT are +9-12%
Does 14.77 sound right?
G-tech speed
G-tech HP vs time
G-tech Gs
You should have the HP and weight to run 95mph with your setup. Only problem is your times are varying soo much. I avg. 95-96MPH on my G-Timer which is only .5-1mph off track #s so I know I am withing the 94-95mph range and I have a lil extra weight on you I think. I am at 4700lbs right now.
What did your truck dyno at and what kind of dyno?
I think the reason why the thing is not consistent is the tune, some days it runs great and other days it doesn't seem to run as well. I think I am running rich at WOT 920-955 on the O2's, and because my LTFT are + it adds fuel based on the % its at before you go to WOT. The truck is a dog out of the hole too, till about 3000 rpm.
I have never had the truck dynoed.
kr1s
08-24-2015 05:34 PM
smokeshow
08-23-2015 08:23 PM
therock
08-23-2015 01:37 PM
