G80 Locker
Old 07-23-2002, 09:13 AM
AKZ71's Avatar
Default G80 Locker
Hey guys I have a differential question. I have the stock G80 locker in my truck. My roommate has a truck identical to mine the only difference being mine is 01 and his is 02. He has been complaining that his tires squeal when going around corners at low speed. My truck does not do this. I thought the cornering tire squeal was common on locking rears. I have also noticed that when I can get my tires to spin some times I only leave one strip on the road. Could this be because I have older tires or could my differential be junk?? I am thinking it is not the tires because this past winter on ice I could look in the rearview and see where I was spinning only one tire. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Any comments are appreciated.
Thanks,
Kevin
Old 07-23-2002, 09:18 AM
Default Re: G80 Locker
Akz71 i thought i had a locker and had the same things going on after a look i found i had no posi unit...
________
Herbal Shop
Old 07-23-2002, 10:19 AM
RED2K's Avatar
I know what you are going through. i went to the dealer and gave them my vin # and found out what i had. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old 07-23-2002, 10:29 AM
AKZ71's Avatar
Wow that sucks. I paid for the locker on my truck. It is listed as an option and comes standard with the offroad package. Maybe I should pop the hatch and take a look inside.
Old 07-24-2002, 03:18 PM
AKZ71's Avatar
Is there any way to tell if it is a locker besides for popping the cover off of the pumpkin? I was told that if you jack the rear end up and both wheels turn the same direction you have a locker and if they rotate the opposite direction that it is an open diff? Is this true?
Old 07-24-2002, 03:29 PM
AKZ71's Avatar
I read up on the factory G80. It seems to me the thing is a piece of junk. It will only lock below 20mph. No wonder I can only spin one wheel. For more information check out the following website. Thanks for all the help. Eaton Torque Control
<small>[ July 24, 2002, 03:29 PM: Message edited by: AKZ71 ]</small>
Old 07-25-2002, 12:15 AM
CashDudeHomie's Avatar
Dude, it could be a good thing too. If your axle locked at like 30 mph on a wet or icy road, you would probably start sliding sideways and wreck.
Old 07-25-2002, 08:21 AM
AKZ71's Avatar
I guess that is possible. I have been seriously thinking about putting an Auburn in it. The more I look at the G80 the more it looks like some cheesy piece of junk. The article says it only locks up at speeds below 20mph. Does this mean that as soon as I hit 20mph the thing unlocks? Or does it mean that it will only lock up at speeds below 20 but will remain locked until the tires stop spinning. Unlike all you Texans I spend about 8 months out of the year driving on ice. Makes for some pretty good adrenaline rushes. Nothing like cruisin at 60mph going to WOT and spinnin all 4 tires <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 08-01-2005, 02:55 AM
NoChrome's Avatar
dude your set-up is good for off roading, the locker senses an rpm difference of 100rpm between the wheels and lockes up (good for mudding) and above 20 mph it stays open too keep the *** end of the truck under control at high speeds on wet, or icy roads. There might be a vin code sombody knows for that locker, but chances are its an eaton locker.
Old 08-01-2005, 07:48 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Yeah look on the tag in the glove box where all the codes are and look for G80 if its not there then you dont have it. That simple.
Quick Reply: G80 Locker
