gasket set???
gasket set???
Ok so I got a 6.0 core from work... I was wondering if anyone knew where I could get a rebuild kit. I was looking for a crank kit, no luck; a gasket "set" for all the covers and seals, no luck; and I was looking for a rebuild kit, new crank bearings and seals.... I have found nothing.... I know I can get a forged rotating kit but all i want is a stock, CHEAP rebuild.... Any help will be greatly appreciated, and I hope this is the right place for this... forgive me if its not...
Thanks
Brian
Thanks
Brian
SDPC is a sponsor and has most/all the gaskets you need. Look for the head/cam replacement kits, they have everything short of oil pan and rear main for about $250 ( includes all the head and pulley TTY bolts! ).They also might have the bearings else check the Cleavite website as they make main and rod products ( HC77 series ) for the GenIII platform. One suggestion is to look at the 5.7L LS1 or LS6 Camaro/Corvette sections and not 6.0L specifically. The crank, rods, and mains are identical on all GenIII motors except the 4.8L ( different stroke ).
A great cheap "rebuild" crank kit could come from someone who did a stroker assembly. The bottom ends are very sturdy and you should be able to find plenty of used parts here and/or on eBay. Biggest expense will be shipping, those assemblies run close to 100# or so.
Good luck and happy hunting. GM SDPC------->
