Gear help
Old 02-06-2004 | 07:06 AM
RED2K's Avatar
Default Gear help
I need to know what backlash setting for these 4.10. It is shifting hard in between shifts. It never shifted like this before. please help, thanks in advance
Old 02-06-2004 | 07:14 AM
6gear's Avatar
Most gears have a backlash between .008 and .012. My Richmond gears specified .008.
Old 02-06-2004 | 08:04 AM
RED2K's Avatar
These are GM gears
Old 02-06-2004 | 12:59 PM
6gear's Avatar
These are GM gears
Backlash should still fall in this range
Old 02-06-2004 | 01:06 PM
Flyer's Avatar
I've been told that a shift will be harder with a lower gear.
Old 02-08-2004 | 10:13 AM
6gear's Avatar
It will be a lot more noticable, If you have ever put a 4x4 in low range and got on it through the gears you can really notice a difference in the shifting but it has nothing to do with the transmission it is the reduction in gear ratio that makes the vehicle react quicker which gives the feel of a harder shift.
Old 02-08-2004 | 12:56 PM
Silvette_02's Avatar
Not trying to insult or anything, but when you set the backlash, make sure your carrier bearings are preloaded. This makes a difference. Also, would be a good time to mark the teeth to make sure your contact pattern is right.
.008 to .012 is a good range. Should be no more than .003 variation though.
Josh Hucks
Idryfly5
09-02-2022 08:55 PM
Oobray
06-13-2022 03:38 AM
blownss27
08-14-2020 08:27 AM
jtphelps289
09-29-2015 12:00 PM
Cowboy Tom
09-05-2015 04:29 PM
Quick Reply: Gear help
