gears gears gears
#21
I agree that 4.10s are a nice overall gear. I would recommend them for a N/A application.
If you plan on drag racing with a 28" tall slicks, with a power adder (nitrous) and a converter, I would go with 3.73s or 3.90s.
With my current setup (TCI 3000 stall, 30.5" Toyos, 125shot), I am barley making it through the 1/4 mile on spray (top of 3rd gear). I would assume that with a shorter tire, I would probably run out of gearing.
Hope this helps.
Hope this helps.
#22
Originally Posted by 03silverado5.3
Not an option in a 1500 5.3. My stock tires are only 29" tall
I remember when pickups came with 29 to 30 inch tires and 4.10's which no overdrive. Even 29's with 4.10 and OD would not be a problem or a reason to get non standard 3.90's that has no native ECM support. I for ten would feel like abot a 2.85 axle ration in OD which is tall.
#23
I ran them in my 1500 5.3 Avalanche... I don't rememer the tire sizes off hand, but the truck felt very similar to this one.
#25
We have had enough of your old time stories of the past
Ill bet those trucks did the 1/4 in 14 seconds and got 20 MPG too huh
#26
Originally Posted by MacADaYear
This is 2004, not 1904 grandpa. Take your medication and goto sleep old man
You are suck a A&# h@$e and I am not the only one that sees it too. Grow up[ man. If it was not for us older guys young know it alls would not even be here. Some times you can learn a lot if you listen to others instead of yourself speaking.
#27
PM me We can go back and forth all you want
