Gears or TC?
Originally Posted by F8L Z71
I'd just get the converter. It's cheaper and won't kill your gas milage. IMO the only time I would do gears in a 4x4 is if you're going to 4.56s or larger. From 3.73s to 4.10s isn't enough of a difference to warrant the $1300-$1500 price tag. <.. Prices for the swap here in Norcal
If I wasn't concerned with gas milage I'd do a 4.56 swap in a red hot second. Then again, I kinda like doing 60mph 1st gear drops with my 3.73s, 32" tires and 4L80E. LOL
Get the converter it won't hurt your fuel milage.Your right foot will hurt your milage ,because you won't be able to keep your foot out of it after you install the converter.
Need some help...
I'm not really familiar with a torque converter, can someone explain what it does, please. Sorry for my lack of knowledge. I'm just turned 16 just got my truck last month. I have a 99' regular cab sierra 4.8 short bed. I just put 285/50/R20 tires on it and it slowed it way down. I don't go to the drag strip at all, just street race. I don't know what gears come stock on this truck, but I was thinking of putting 4.10's to compensate for the bigger tires. Does anyone have advice? I just want to have good fun tire burning TAKE OFF POWER!! but still be able to drive 80mph without the rpm's getting to high. But in this auto truck does it really hurt your high speed driving if you get lower gears because of the overdrive trans. Any advice will help.
Thanks,
Nick
Thanks,
Nick
Tipsz,
i'd do the converter, it's cheaper than the gears anyhoo.
nick,
since you went to a bigger tire, i'd do the gears. a stall basically gets you in ur powerband quicker and keeps you there.
Chad
nick,
Chad
Tin Foil Hat Wearin' Fool
How a stall works when driving-Instead of punching it from a red light and the rpms jumping up to 1800 and having to wait for the engine to start getting in its powerband where it really feels like its starting to pull hard a stall(a 3000 stall) when you step on it from a red light it automatically jumps up to 3000 rpm and since you are making alot more power at 3000 then 1800 you have alot better acceleration. Once you get off of it the torque converter locks up at say 40mph(usually the speed tuned for tc lock-up) and your rpms drop to what they used to without the stall. Get the stall it will be alot funner. Screw gears they arent going to help you as much off the line and they will hurt you on the highway. BTW you probably have 3.42 gears in that rcsb. If it doesnt say gt4 or gt5 I believe then you have the 3.42s.
It will hardly spin the tires right now with 20's and stock gears. If I stay with stock gears and get the convertor will it spin the tires from the start easier. If know alot of people want traction, but I just want to burn rubber!! Thanks.
PS. So your saying when I stop at a light and want to take off I have to rev the engine to 3000 rpms before it will take off, dosen't that get anoying? Thanks for the advice.
jtphelps289
09-29-2015 12:00 PM
