gen I sbc 350 - LSx retrofit
#42
Originally Posted by SS_bnoon_SS
Looks like things are coming together nice for you. I like the LT1 rails, but you should drill/tap them for AN fittings with braided line instead of the ugly stock tubes. I did an LT1 conversion for my old TA and it made it look a ton better. It also lets you use over the counter FPR instead of the higher priced LT1 specific crap. Of course it sounds like you already might have known that...
Originally Posted by thunder550
Lookin good!!
#43
Looks like GM beat you to it well at least on the new 4.3L
DIRECT IGNITION SYSTEM (Chevrolet Silverado, GMC Sierra)
The ignition system is now fired electronically, and uses three coils, each of which fires two cylinders. The coils are mounted above the former distributor location. A shorter oil-pump driveshaft was necessary to replace the former distributor shaft-driven oil pump.
http://www.cheersandgears.com/forums...hp?t10823.html
2007i Vortec 4.3L V6
You should be able to use parts of that engine on a V-8. The oil pump drive and front mount 58x pick up ring as well.
#44
that's quite different than the setup we're gonna run, but in theory its the same concpet.
as of now I can't do the EFI conversion for the buggy since some things have come up and everything is for sale on here and ls1tech along with the dune buggy itself.
gmcyukon
10-03-2015 11:03 PM
elir_mn
09-19-2015 11:43 AM
