Gen III cam swap -- things needed?
Hey guy's,
I finally got almost everything together for my cam swap, but need the required gaskets and such. I stumbled across a thread that had a GM part number for a kit that included everything needed, but now I can't find that thread.
Does anyone know the part number, or if there is such a thing?
Thanks in advance...
Tony C.
Tony C.
You might want to get water pump gaskets, but everything should be re-usable. They are either o-ring type, or they have a sealing ring built into the gasket. I just did a cam swap in my 04, and it's fairly easy. Make sure you have a new balancer bolt.
Import Moderator
dowel rod for the lifters and you should be good
here are some part numbers of stuff youll need and some gaskets just incase
timing cover gskt - 12574294
H20 pump gskts - 12588372
crank seal - 12585673
balancer bolt - 12557840
valve cover gskt - 12560696 x2
Import Moderator
while your at it if you got the money id recommend a double roller set, hardend push rods, and springs if your cam kit doesnt already come with them... shouldnt cost you over $800 and a VERY good investment
red RTV for replacing the cam cover, that cost me a night when I did mine.
I got a new crank bolt but it was not longer???
I agree about the cam swap kit, I only used the bolt, crank seal, water pump.
I resued the valve cover, cam cover and they came with intake gaskets that I did not use...
Thanks again...
I live 120 miles from the nearest Chevy dealership, so it's important to have everything needed before I start -- the local Napa usually has to "special" order stuff that they would not normally sell day to day.
I'll be sure to get beer.
Tony
Tony
Import Moderator
im sure you probably know this but just incase figured id throw it out there anyways
o just thought of something... lube that cam up really good wit like comp cam lube or something
run some cheap *** oil wit a cheap filter for like 30 mins and just let it get all the cam lube out... then put your good stuff in
GrooveCityZ71
08-31-2015 12:05 PM
Suburban2500
07-19-2015 04:50 PM
