GM header stud pictures
Old 03-31-2009, 09:47 PM
  #21
nonnieselman's Avatar
Originally Posted by EVILGMC
glad you all are enjoying these. i think i paid about $25 for the studs and used a different style lock nut.
What type of lock nut did you end up goin with?
Old 03-31-2009, 09:53 PM
  #22
EVILGMC's Avatar
http://www.jergensinc.com/infodir/ca...?GroupNum=1980
spinner grips. they work really really good.
Old 03-31-2009, 10:08 PM
  #23
GMCtrk's Avatar
Originally Posted by hirdlej
Jesus you guys will spend money on anything won't you? LoL $50-$100 for bolts no thank you
Well considering I will never ever screw around with bolts that break off in the heads again, I see these as a good investment Im pretty sure you can get these cheaper at gmpartsdirect, I believe $42 was full retail. When you look at it though, it's still cheaper than stage 8 locking bolts and stuff like that
Old 04-01-2009, 07:10 AM
  #24
12 Second Club
fastlt1's Avatar
How well do they stay tight?
Old 04-01-2009, 10:06 AM
  #25
High on diesel fumes
thunder550's Avatar
They aren't studs, but if you want something that will not loosen, guaranteed, check out Stage 8 hardware.
Old 04-01-2009, 10:08 AM
  #26
EVILGMC's Avatar
mine stayed perfectly tight for over a year with the gm studs and jergens spinner grip locknuts
  #27
GMCtrk's Avatar
Very well...better than the stock bolts
Old 04-01-2009, 10:22 AM
  #28
CashDudeHomie's Avatar
I have the stage 8 bolts like the pic a few posts up. The locking pieces were such a PITA that I threw them away after the second time I had to remove them. Since then, the bolts have never tried to back out by themselves. If I ever have to pull the headers again, I think I will go with these GM studs. Nice thread and thanks for the pics.
Old 04-01-2009, 11:39 AM
  #29
Whippled 496's Avatar
8.1Ls come stock with studs. THey were left in place on the passenger side and the header slipped right over them. On the drivers side it was a different story. No way to get the header past the studs with the steering shaft right there. Had to back the studs out to get the header on on the drivers side.
Old 04-01-2009, 12:04 PM
  #30
PT's Slowest Truck
budhayes3's Avatar
Yeah well - the more you run the bolts in and out the more you'll wear the threads out. Less likely to break a bolt Besides, it'd be my luck after installing the headers to swap the bolts out for studs and break the damn bolts.
Oh and not all of us can get an account setup at a GM parts counter. Or can we??? How do I join the secret discount underground?
I work at a dealership (not GM), but just the fact that I work at one has always gotten me a discount. I just mention where I work and I get the "dealer discount". It also helps that I used to work with the parts manager of the GMC dealership 1/2 mile from where I work...I just zip there on my lunch and order what I need.
hirdlej, next time you go to the Chevy parts counter, just say that you work at "enter name of local dealership of your choice here", and you'll probably get away with it. I've had friends go to dealers to pick up parts and had them do that with no problems
Quick Reply: GM header stud pictures
