GM header stud pictures
#31
Are these nuts reuseable?
Here is a quote from the previous thread about the GM studs and nuts.
https://www.performancetrucks.net/fo...d.php?t=437188
But they are actually special nuts, triangular in shape with some kind of threadlocker on them.
#32
hate to pop alot of bubbles , lol
but ever had a factory stock bolt break ? if yes , then welcome to a factory stud breaking , granted it will happen fewer times , but GM doesnt use the best grade , they buy from the lowest bidding company
but you will have the studs back out more often when trying to take the nut off , and it really pisses me off when that happens
also i think the ecotec motor uses the same thread studs as the bolts the LS motors use
the ends on the GM studs is a inverted torx , so you can screw them in or out , also allows the nut to thread on easier
#33
PT's Slowest Truck
