GM header stud pictures
Old 04-01-2009, 02:28 PM
  #31
1998chevy1500's Avatar
Are these nuts reuseable?
Here is a quote from the previous thread about the GM studs and nuts.
https://www.performancetrucks.net/fo...d.php?t=437188
But they are actually special nuts, triangular in shape with some kind of threadlocker on them.
Old 04-01-2009, 11:05 PM
  #32
s/c'd cav's Avatar
hate to pop alot of bubbles , lol
but ever had a factory stock bolt break ? if yes , then welcome to a factory stud breaking , granted it will happen fewer times , but GM doesnt use the best grade , they buy from the lowest bidding company
but you will have the studs back out more often when trying to take the nut off , and it really pisses me off when that happens
also i think the ecotec motor uses the same thread studs as the bolts the LS motors use
the ends on the GM studs is a inverted torx , so you can screw them in or out , also allows the nut to thread on easier
Old 04-01-2009, 11:20 PM
  #33
PT's Slowest Truck
budhayes3's Avatar
Toyota and Lexus use inverted torx on their studs, but the studs in the pics that GMCtrk posted sure look like hex to me...
Old 04-01-2009, 11:29 PM
  #34
s/c'd cav's Avatar
they do on 1 side , other side does look like a hex , lol
i know ive had to use my inverted torx bits alot on the eco's
Old 04-02-2009, 09:47 AM
  #35
GMCtrk's Avatar
they are all hex, no torx
Old 04-02-2009, 10:08 AM
  #36
EVILGMC's Avatar
they are 5mm or 5.5mm hex.
Old 04-08-2009, 09:34 PM
  #37
GoatChs's Avatar
Suppose that a dab of Loctite 271 would keep those in?
Old 04-08-2009, 09:46 PM
  #38
could one aquire such things at orielys or auto store?
Old 04-08-2009, 09:52 PM
  #39
nonnieselman's Avatar
Give it a try..
Old 04-08-2009, 09:56 PM
  #40
s/c'd cav's Avatar
its possible
Quick Reply: GM header stud pictures
