gm header studs pn needed
#45
10 Second Truck Club
Here is a tip, if you have header bolts that won't stay tight. Put a round or two of teflon tape on them, they will stay tight and come out easy when you want remove them.
I have Stage 8 header bolts and use anti-seize, never had a problem and have never used the locks that come with them.
I have used the tape on others that give a problem and it works well.
#46
traveling mod
#49
finger tight on the studs and 22ft lbs on the nuts. i did not use gm nuts though....got some jergens spinner grip all metal locking flange nuts. they have worked perfectly.
****...was I the first one on here to use the GM v6 studs?
