gm header studs pn needed
Old 05-07-2010, 08:41 PM
  #41
traveling mod
andrew383's Avatar
Back from the dead
Did anybody put anitseize on the studs either in the head or the nut side???
Old 05-07-2010, 09:10 PM
  #42
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
And has anyone removed the nuts without the stud coming out? A friends truck that I put these on almsot all the studs came out with the nuts when we pull his headers...
Old 05-07-2010, 09:15 PM
  #43
GMCtrk's Avatar
If you look at the end of the stud it takes a small hex socket. I stick a ratchet on that and a wrench on the nut. Nut comes right off, stud stays intact.
Old 05-07-2010, 09:32 PM
  #44
skolman91's Avatar
Originally Posted by andrew383
Back from the dead
still havent gotten mine on yet, but i plan on using some. i dont see why you wouldnt.. just cheap insurance if your planning on keeping them on for awhile imo..
Old 05-08-2010, 10:15 AM
  #45
10 Second Truck Club
CurtD's Avatar
Here is a tip, if you have header bolts that won't stay tight. Put a round or two of teflon tape on them, they will stay tight and come out easy when you want remove them.
I have Stage 8 header bolts and use anti-seize, never had a problem and have never used the locks that come with them.
I have used the tape on others that give a problem and it works well.
Old 05-08-2010, 08:52 PM
  #46
traveling mod
andrew383's Avatar
Maybe we should sticky this thread
Thats kinda what i was thinking...I used anitseize on the stock ones when i installed my LLP's
Thats a real good idea
Old 06-29-2010, 06:53 PM
  #47
j_ahlheim's Avatar
hate to beat a dead horse here but I got the studs installed but was curious what you guys torqued the nuts down to?
Old 06-29-2010, 09:48 PM
  #48
brent5631's Avatar
A half past snug.
Old 06-29-2010, 10:19 PM
  #49
EVILGMC's Avatar
finger tight on the studs and 22ft lbs on the nuts. i did not use gm nuts though....got some jergens spinner grip all metal locking flange nuts. they have worked perfectly.
****...was I the first one on here to use the GM v6 studs?
ZONES89RS
21
09-24-2015 05:58 PM
Bluecollar Hotrods
07-16-2015 08:52 PM
Aboss
07-09-2015 10:28 AM
Sbrown06
07-09-2015 09:21 AM
Quick Reply: gm header studs pn needed
