GM made the LS6 intake swap easier!
Old 08-19-2007, 07:57 PM
1TRUESS's Avatar
Thanks! Now is that pump setup for truck accessories or f-body?
Old 08-19-2007, 08:01 PM
10 Second Truck Club
67SS509's Avatar
It's for the truck accessories. GM actually calls it the L92 pump.
Old 08-19-2007, 08:06 PM
2004SSS's Avatar
i had to use that pump on my new set up too, i have a 90mm tb in the same spot as a ssr manifold and it still hit the water pump at first.
Old 08-19-2007, 08:42 PM
agreif's Avatar
You guys have a PN for the hose that goes with that? haven't ordered the hose for top rad hose for that yes so I have a little necking when using my 01 hose.
Old 08-20-2007, 11:12 AM
67SS509's Avatar
Hose part #19130027..sells for $33
Old 08-20-2007, 03:53 PM
1TRUESS's Avatar
Off the the stealership!!
Thanks, I will be ordering the hose too.
Old 08-20-2007, 08:45 PM
14 Second Truck Club
I just got mine in the mail today for my FAST 90/90 set-up. Will my 160* thermostat fit on it?
Old 08-20-2007, 09:07 PM
67SS509's Avatar
07 uses a different thermostat. Got a 160* from SLP for $30.
Old 08-20-2007, 09:16 PM
PT's Slowest Truck
budhayes3's Avatar
Sooooo....on a cable driven throttle body, what all is involved with doing an LS6 manifold swap when using this water pump and upper hose? Is it just a matter of swapping intakes and fuel rail mods, or do the accessoris still need modification?
Old 08-20-2007, 09:26 PM
Crap! Thanks for the info! Do you have a part #?
Quick Reply: GM made the LS6 intake swap easier!
