GM made the LS6 intake swap easier!
Old 08-20-2007, 09:51 PM
  #21
1TRUESS's Avatar
Can we still used the old style thermostat housing with the 07 thermostat?
Old 08-21-2007, 08:05 AM
  #22
eallanboggs's Avatar
67SS509 With all the money it appears you've spent on the engine where is the Meziere?
Old 08-21-2007, 11:52 AM
  #23
10 Second Truck Club
67SS509's Avatar
I give up....where is it If I spend much more I'm going to need a divorce lawyer!
Old 08-21-2007, 01:35 PM
  #24
1TRUESS's Avatar
What part number did you buy for the thermostat, 100228? Because I found this part number but it says 04-06, 07 Classic and 100229 for 07. I think we need the 229, right?
Check to see what you have.
Old 08-21-2007, 05:28 PM
  #25
67SS509's Avatar
You need the 100229.........
Old 08-21-2007, 05:30 PM
  #26
67SS509's Avatar
Here is a pic comparing the water hoses.....
Old 08-23-2007, 04:43 AM
  #27
agreif's Avatar
Wow, thanks. Definitely looks like the one on the right curves more for the new water pump inlet angle, thanks!
Old 08-23-2007, 08:28 AM
  #28
SS_bnoon_SS's Avatar
Sooooo....on a cable driven throttle body, what all is involved with doing an LS6 manifold swap when using this water pump and upper hose? Is it just a matter of swapping intakes and fuel rail mods, or do the accessoris still need modification?
No mods to accessories because the upper radiator hose doesn't come out the front like the F-bodies and vette water pumps that were used for these swaps in the past.
Old 08-23-2007, 08:39 AM
  #29
kw05silverado's Avatar
I haven't read this whole post but isnt our truck manifolds better than the ls1 and ls6?
Old 08-23-2007, 09:04 AM
  #30
With bolt ons only, most likely, but once you get big cubed, cammed and new heads the truck manifold holds you back at upper RPM's.
Quick Reply: GM made the LS6 intake swap easier!
