Going with a bigger cam worth it?
Old 09-29-2006, 08:07 PM
2000 SILVERADO's Avatar
There isnt any fabbing at all with the pacesetters and ORY. You can weld in a resonator in front of oyur muffler to quieten it down. Ill take you for a ride in my truck when its back up and running. You just need the right exhaust system. CORSA! Efans are worth 1.5mpg and 10hp and the UD pulleys are worth 10hp. Nickels and dimes add up
Sorry guy, I need cats so my truck will pass emmisions tests. Well, I might be able to make it work, if that resonator really helps and I can somehow run cats. Honestly I just want to run high 12s or low 13s at least, I just figuered the best way would be some heads and be done with it, but if LTs, e-fans, underdrive pullies, a 160 termostat, and a 3000 stall will get me there, then that works too.
Old 09-29-2006, 09:19 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
BlueCajin ran 12.50s with lts, 3K stall, CAI, gears, efans, Nelson tune and a 220 camI think that speaks for itself. You can get some custom pipes made to retain teh cats.
Old 09-30-2006, 07:56 AM
11 Second Truck Club
bluecajun5.3's Avatar
bigger isn't always better unless you have the supporting bolt-ons.
all the parts have to be matched to make a good, reliable combo.
Hmguyton
08-09-2015 05:38 PM
JordanH
08-08-2015 07:59 PM
Sexyrado327
08-02-2015 04:08 PM
steves86ta
07-28-2015 10:21 AM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: Going with a bigger cam worth it?
