Is this a good cam for my 5.3
2002 sierra (bolt ons in sig) is the comp cams xr275hr a good fit for my set up? I'm going with ls6 springs and a hardned pushrod 7.400 but I don't want to do any more work to the heads they are stock. The torque converter is also stock. Cam specs 212/224 .566/.568 112* lsa. What are your opinions on this the truck is a dd but I just want a little extra power.
I like mine. I would like the truck more if it were on the road!
That cam is very lumpy and pulls hard right to 6800. As a trade-off, power below 2200 is less than stock. With your 4.11 gears, you should enjoy it. Pushrod length changes as your valve seats wear.
If its going mainly be a daily driver and not really take it to the track a 3k stall would be fine.. as on the street a big stall is going to be useless unless you have drag radials or good tires..
