got a 4.8 want it faster. any suggestions
#21
Originally Posted by dirt_track_racer_81
what ever floats your boat baby..by the time i got to 4000 bucks i already had a blast and walked away from supercharged and turbo trucks, ls1 camaros and firebirds, nitrous mustangs in a big as ****** truck..there was guy a just a week ago that blew up his supercharged 6.0 ask him how many miles he had on his seto up and ask him how his daily drivin was..like i said if i had the money id go twin turbo'd, for me its a lot easier for the money i make buying a bottle a time..instead of saving up for a year for 5-6 grand for a decent turbo kit and the accessories...and by the way where i work at i get nitrous half off..really not to tell any one..so cut that 3600 in half..i was just saying what it would be for every one else..
there is not a stock motor around that is going to live up to either power adder for a long time. The way I see it, its all in the tune.
#22
#23
thats perfectly right.. no motor will hold together for a long enterval..if your tuning is off a lightest bit it can be harmfull..im an expeirenced tuner as i tune gm and ford cars at a dyno shop and i run 91 mixed with 111 octane leaded racing gas..in my truck
#24
wow, you work for a tuning shop? maybe you could help me out with some tuning.
#25
yes i would help you if you really needed it but if your being an arogant *** then
#28
I think I would get a tune, modifiy your intake by taking the piece that connects the box to the fender. That will double your air intake. Also, take out the screen on the mass air flow sensor. Both of those things don't cost a dime and make a real difference.
Next put on a true dual setup with an h or X pipe in there. Mandrel bent if you can afford it. Don't go to big, because you will loose some bottom end.
The biggest difference is lower gears!!! With those big meats on there, you will need some 5.56's, or 4.56's. That will help you more than any other thing you can do bar none. And it is way cheaper than a blower. A S-charger will give you more grunt, but it comes at a huge price. gears are much cheaper, and it will give that little engine a chance to get going.
#29
12 Second Club
I would avoid taking the screen out, it's causes more headaches than it's worth..
and there isnt any "real" performance gains to warrant taking it out..
some guys get lucky, and it doesnt cause any problems, and then some do..
I removed mine, didnt notice a lick of diffrence, and was lucky enough to be able to put it back in.
legerwn
56
11-15-2015 10:21 PM
Tydriver
45
10-23-2015 09:19 PM
