Got a 4.8L, What can I do to get some more HP?
Re: Got a 4.8L, What can I do to get some more HP?
Converters are the "black holes" and "voodoo" of cars and trucks. They are strange, complicated, and misunderstood.
First, stall is based on input torque. I.e. an anemic, low compression 350 may be able to stall a converter to about 2000 rpm. A hot, higher compression with good heads 350 may be able to get that stall up to 2600 rpm due to making more torque. That is with the same converter. It really depends on your motor.
Stall also is in different forms. There is flash stall, brake stall, and actual stall.
Flash stall is, with no traction problems, the peak RPM or the quick jump of the engine RPM's on with the converter. This isn't the best way to measure stall. Insane amounts of torque can make a 3000rpm stall to 4200rpm+
Brake stall is, holding down your brake and gassing the ride with the other foot. That doesn't work too well either b/c you will generally begin to light up the rear tires.
Actual stall is if you had a line lock on your trans (holds R+D together) so you don't move and your RPM's rise to your stall speed. If you have a 3000rpm stall, that is what your engine should rev to with the line lock on. You would launch off of that.
Softness depends on the stall and size you go with. High stall, small converters are "loose" converters if you will. Larger diameter usually help keep the looseness away and keep the factory towing up. These act more stock with higher stall. The softness is more likely to be with the part-throttle shift than the WOT ones.
Looseness is hard to explain. Like you'd have to give the vehicle a bit more gas to get moving and depending on diameter. Generally your part throttle putting around rpms are about 2000-2200rpm.
Precision Industries recommends a TransGo shift kit (at least they used to, prolly still do) to be installed with the converter. Check out all the car mags like: 5.0 Mustang, CarCraft, Hot Rod, GM HighTech, etc they all install shift kits with the converter install.
A high quality TransGo kit addresses trans problems and corrects them. 3-4 burn up, 2-4 band loss, etc. They boost line pressure but also keep more fluid on the clutch packs, and get rid of the slop shifts.
I recommend at least the Corvette servo but prefer the Superior billet servos. On the passenger side of the trans is the 2-4 band apply servo and the overdrive servo. I think it is silly to not install both of the bigger servos at the same time you install a shift kit as you have to clearance the band. The servos increase holding capacity (the OD billet is 10% greater over stock. Intermidiate billet is 35% more apply over 'Vette servo, so I'd figure about 50% greater than the non-'Vette servo)
Finally, with a high stall converter, install a large transmission cooler. Even if the instructions say it is okay to use the factory cooler/heat exchanger get one. They are cheap insurance. $50 cooler or $2000 transmission?
Alot of guys swear by the yank, but TCI sells a 3000 stall for $450. And gears you can get done with a locker for @ $800. That should make that little motor feel more like a 5.3. J/K
Tydriver
45
10-23-2015 09:19 PM
lycominghunter
26
09-25-2015 07:50 AM
48l, aftermarket, band, converter, converters, cooler, descreened, large, limits, maf, performance, power, stall, torque, towing, transmission
