got the cam spec'ed from Pat G , need your help
Old 10-03-2011 | 07:39 PM
  #21
08cheyennesc's Avatar
Don't gen IV engines come with ls2 timing chain?
Old 10-04-2011 | 12:17 PM
  #22
sand man's Avatar
i wish...ill check now
Old 10-04-2011 | 02:19 PM
  #23
06Sierra2's Avatar
i thought anything after like 05 had a ls2 chain? i remember a thread awhile back about this.....
Old 10-04-2011 | 02:22 PM
  #24
06Sierra2's Avatar
Originally Posted by iamkeniff
Think this will prove that his truck with stock heads and LS7 lifters require a 7.425" pushrod
ah ok, interesting. thanks for that, im still learning about the gen4's i guess. i also didnt realize the dod lifters and ls7's werent the same length. i guess i need to
Old 10-04-2011 | 02:33 PM
  #25
iamkeniff's Avatar
Yeah something about the LS7 lifter needing more preload or some bs im not for certain on it.
Im running a stock chain on my 5.3 and 6.2 i just swapped to the LS2 wedge vs the pos tensioner GM puts. 6800 with the 6.2 MANY times with no issues
Old 10-04-2011 | 06:57 PM
  #26
sand man's Avatar
so do you recomend using a stock timing chain??
Old 10-06-2011 | 10:06 PM
  #27
sand man's Avatar
the chain is the same as the one on my truck the new one is for ~50$
SO do you recomend changing the gear to a 3 bolt cam gear
what part number?
dampner? iknow the part number . change or not
arp head and cam bolt numbers please
Old 10-09-2011 | 03:01 AM
  #28
sand man's Avatar
contacted a vendor here , its been six days and no replay.
any other vendor please PM me a price
any one knows a good cheap place to order from
this is what im buying, all the GM parts will be bought from the stealership
compcams custom cam 21*/22* .6**”/.6**” 111LSA +4 advance
patriot 8501 dual valve springs .660
OR
PAC 1518 .650
what do you guys recomend(is it true that dual loss some hp over the single?)
7.425 chromemoly pushrods
Melling high valume 10296 oil pump
PROFORM ls1 valve spring compressor
here are the GM parts wich ill be buying from here
TIMING CHAIN 12586482 = 54.59$
CAM sprocket 12586481 = ~15-20$
Timing Chain dampener 12588670= 20$
LS7 LIFTERS 12499225 = 140$
Lifter Trays x 4 12595365 = 32$
LS2 VALLEY COVER 12570471 = 100$
MLS head gaskets GM 12589226 =30$
Water pump gaskets GM 12588372 = 6$
Front oil seal GM 12585673 = 20$
PF48 oil filter = 5$
6l oil=25$
Old 10-09-2011 | 03:21 AM
  #29
sand man's Avatar
oh yeah ARP HEAD AND CAM BOLTS PART NUMBER PLEASE
Old 10-09-2011 | 03:30 AM
  #30
SDPC and TexasSpeed is where I got the best deals on my parts,check their sites and see who has the cheapest price, most vendors are too busy to return emails ,if you find what you need at the price you like order online ,they ship fast I got everything in 3-4 days (except cam ,came from Geoff) using the cheapest shipping offered.
