got the cam spec'ed from Pat G , need your help
#24
#26
so do you recomend using a stock timing chain??
#27
the chain is the same as the one on my truck the new one is for ~50$
SO do you recomend changing the gear to a 3 bolt cam gear
what part number?
dampner? iknow the part number . change or not
arp head and cam bolt numbers please
what part number?
#28
contacted a vendor here , its been six days and no replay.
any other vendor please PM me a price
any one knows a good cheap place to order from
this is what im buying, all the GM parts will be bought from the stealership
compcams custom cam 21*/22* .6**”/.6**” 111LSA +4 advance
patriot 8501 dual valve springs .660
OR
PAC 1518 .650
what do you guys recomend(is it true that dual loss some hp over the single?)
7.425 chromemoly pushrods
Melling high valume 10296 oil pump
PROFORM ls1 valve spring compressor
here are the GM parts wich ill be buying from here
TIMING CHAIN 12586482 = 54.59$
CAM sprocket 12586481 = ~15-20$
Timing Chain dampener 12588670= 20$
LS7 LIFTERS 12499225 = 140$
Lifter Trays x 4 12595365 = 32$
LS2 VALLEY COVER 12570471 = 100$
MLS head gaskets GM 12589226 =30$
Water pump gaskets GM 12588372 = 6$
Front oil seal GM 12585673 = 20$
PF48 oil filter = 5$
6l oil=25$
OR
PAC 1518 .650
6l oil=25$
#30
SDPC and TexasSpeed is where I got the best deals on my parts,check their sites and see who has the cheapest price, most vendors are too busy to return emails ,if you find what you need at the price you like order online ,they ship fast I got everything in 3-4 days (except cam ,came from Geoff) using the cheapest shipping offered.
