Got my HPtuners today
Old 05-21-2004 | 09:26 PM
WestUAg's Avatar
Does it allow you to store your factory settings and go back to those is you ever need too?
Where did you buy the software?
Old 05-21-2004 | 10:58 PM
Yelo's Avatar
The software is only available form www.hptuners.com
The package costs $510.00 shipped to your door
VCM Suite (the software) contains both editing software (which most agree is easier to use than LS1Edit) AND a data logging/diagnostic package that rivals EFILive in functionality and performance
You CAN d/l and save your stock tune.....and then edit to your hearts content
You can download and store as many .bin files as you like
The site that is most commonly used for LS1Edit help is www.ls1tuning.com ....MOST of the information on there WILL work with VCM Suite as well (some data might need conversion though)
Reading and Programming with VCM Suite is MUCH quicker than LS1Edit (less than 1 min. to read and 27 sec. to write....most '03's using LS1Edit require 10-15 min. to read and 5-6 min. to write)
The software IS NOT locked to one vehicle....it is locked to a MODEL YEAR of vehicle type....for example, if you and your friend own 2 '01 trucks...even if one is a 4.8 RCSB and the other is a 6.0 2500HD you can program BOTH of them with the SAME software/cable package.....and only pay ONCE for the software (c'mon Carputing......try to beat that), you COULD NOT however program an '01 Camaro and a '01 truck with the same software/cable...because those are obviously different vehicle types
I think I got all of the major questions there.....
Old 05-22-2004 | 11:31 AM
hptuners may have a chance.
ls1edit is still #1
and the predator, is a great programmer, the best out of superchips HPP3. you can do alot with predator, you work in conjunction with diablo motorsport to work out a tune for your truck. in some instances that i know they have done better tunes over ls1edit.
Old 05-22-2004 | 12:18 PM
FILE's Avatar
ls1edit is still #1
Can you elaborate on this.
Old 05-22-2004 | 12:46 PM
99Silver6.0's Avatar
Im thinking about dumping Edit. Im gonna have to get my PCM re-added to my cable... $300 dollars is what Carputing wants to do it!!! $200 dollars more and I can get a logging program with the tuning setup.
Old 05-22-2004 | 01:15 PM
SimpleManLance's Avatar
do you have to have a labtop or could i run the cord from my normal computer? also is it hard to learn. and is there anyone in southern michigan that has it?
Old 05-22-2004 | 02:18 PM
MacADaYear's Avatar
I guess you could log idle and see what codes your throwing if any... but you wont be able to log your runs...
Unless you got a REALLY long cable
Old 05-24-2004 | 05:06 PM
Black02Z71's Avatar
I finally got to play with HPtuners today, I was up north at the cottage this weekend getting eaten alive by black flies.
HPtuners rocks, I can read the pcm in less than 2 min, and write in 27 sec. The scanner that comes with it is pretty basic, but they are working on adding to it, like there is a pcm control button on the scanner, if you click on it, it says feature not yet implemented, so there working on it. HPtuners can only get better.
What I have adjusted so far. Working off Predator tune
RPM limit
shift points
raised idle speed
Low and High octane table (Copyed high table to low -2)
added 2 degrees across high table
- LTFT (scaled IFR vs kpa using spead sheet)
tuning_1.0.2.xls
- PE table (X93%)
knock learn min rpm 7000
abuse mode 7000rpm
disabled ses on PO300
HPtuners forum
Old 05-24-2004 | 05:23 PM
greentahoe's Avatar
Did you notice any performance increases from those alterations. Do you have a experience with tuning prior to this?? How easy is it to learn?? Do you think you would have an adequate ability to tune for a supercharger with thise software?? Can it do logs of runs showing Knock, timing, and such??
Old 05-24-2004 | 05:51 PM
marc_w's Avatar
I still haven't got my software........ but....... From the looks of this, I SURE DO miss chaning jets and advance springs.
It seems like you need a college degree in math and a certification in Excel to tune a vehicle.
EDIT:
DOh, I just realized I was on the last page of that Excel tuning guide. No wonder most of it was greek.
Whoever set that up was pure genius.
Quick Reply: Got my HPtuners today
