got my yank, a little info on it.
ok guys, this is probably the last part i need(i hope), if i work my *** off tonight i might get to go for a drive. couple of things about this converter...
it weighs 35lb's, the stock one is 65lb's!! that yank weight is with about 1 1/2 quarts of oil in it, probably not as full as the stock one.
it doesn't have 6 mounting lugs like the yank web site says, at first i thought they sent me a py3400 and not the extreme version, eveything says py3400 not py3400e like it should, i called them up and he told me he built it himself and that it is an extreme, they just dont have a 4l80e cover with 6 lugs on it so it only comes with 3 lugs.
the HD transfer case is 20lb's less than the autotrack version, put the 30lb's with the 20lbs and this thing will probably weigh about the same as before even with the heavy tranny.
got to go to work now
hartinclay
08-02-2015 06:44 PM
gtyler04
07-28-2015 06:21 PM
