Got Nelson Tune in, now truck won't start
#31
17,16,15,14,13,12,11 Drvr
well i was disbelieving as you but after about 3k on the tune the truck droped 4/10 off the 1/4mile times so just give it time and it will happen later, kevin
#32
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
4 tenths? I shold run 15 flats then. When I get my new tune I will give it a couple weeks then run it at the track. We'll see...
#34
Performance Trucks Sponsor
There are several tables that pull timing, if you ask for all TM removed and have a shift kit and servo, I will remove all of the TM that is under the engine section, that is why I call it engine TM.
If you have a fully built trans, I will normally pull all of the other timing tables under the trans section.
I've zeroed out all of these tables and mine is still ticking away, no problems, but I think it will hurt a stock trans over time.
Also, you will feel the internals of the trans working , downshifting, and upshifting more.
I'll pull all of it for you on this next tune and you won't see any timing being pulled.
later,
allen
later,
allen
#35
Originally Posted by Snake Eater
Academy, thats it. Yea, ill be on leave when i come down. Some of that after deployment, make up for lost time kinda stuff.
#37
1 Post
Originally Posted by Hit Man X
I am TqMgt-less with a stock tranny w/ a TransGo and Servos...
cams 98 silverado
07-31-2015 07:36 AM
InsaneDomestics
07-27-2015 02:42 PM
GreyChevy
07-07-2015 08:57 PM
