got the Procharger on , won't idle now
The belt and everything seems to be ok, I dont know if it's the drag from the sc ro what. It will run as long as I give ait a little gas, but will die sif I let it try to idle. I tried this for 5 or so minutes to make sure it wasnt learnign to idle from having the battery cables off. What did I mess up???
<small>[ April 20, 2003, 06:33 PM: Message edited by: samuriarte ]</small>
Re: got the Procharger on , won't idle now
it is idling now. it had to re learn, and I think the sc was dragging a little cause new? It is idling ok now. I left the bypass open to atmosphere instead of routing it to the intake hose of the air cleaner. It blows alot of air damn. Let you guys know in a while how it is doing. I have to figure out the FMU adjustment. Where should I start with the FMU? I have it open about a 1/2 turn. Thanks you guys! Sam
murderedSS
27
10-12-2015 11:13 AM
Shotguntommy
09-15-2015 05:24 AM
