Got a question about the A/C
12 Second Club
when I start my truck up in the after noons at work. ( mind you it has been getting pretty hot here lately, and my truck is black ) the A/C when turned on blows super hot air for about 2-3 minutes. Is this normal or is something not right. Every other black vehicle( which is the only color I have ever owned ) that I have had didnt do this. does my system need to be recharged?
what gives?
Thanks,
Daniel
what gives?
Thanks,
Daniel
It depends on how hot it is inside your truck. I've seen temps of 135+ in the summer time sun. If it cools real good after you drive it for awhile then it is probally working fine.
Mine has been doing that lately too. I think I might have my mechanic check it out, just in case. I drove my mom's 2000 and her's wouldn't cool down, had to drop it off at the mechanics.
Mine blows hot for just a few seconds when I first fire it up but 2-3 minutes is not right. Greg make is right about the recirc. I normally leave mine on fresh and crack the windows when I first start going to suck some of the hot air out of the cab. Try that and if it still blows hot, you may want to have it checked out.
Oh, and make sure the temp *** is turned all the way counter clockwise, in the blue.
12 Second Club
hell if i turned it any more it would be blowing snow out, if it worked right
I'm thinking it might be what was suggested about the ac duct soaking up the heat,cause I parked it under an awning(sp) today at work and it didnt take nearly as long as it did the other day.
Hpinnovate
09-04-2015 02:28 AM
SWINGRRRR
09-03-2015 07:49 PM
