Gotta pull heads now what?
RedXray (09-17-2021)
I've gotten the others out pretty pain free free handing with a drill but you can't get to that back one with a drill like you can the passenger side. I'll pull the manifold off tomorrow to see about the welding idea.
For a 6.0 that BTR is not going to kill any torque, will gain more IMO and if you get someone to tune this which I recommend highly run it on 89 octane to avoid detonation while towing. Check out some of Richard Holdener's video on you tube. He does a great job covering GM performance and cam shaft selection.
Search for You Tube videos on a bolt extraction process known as "Electric Discharge Machining". I had to have this done at a local machine shop to remove a broken head bolt on my grandson's four wheeler - for $75 bucks. Pretty amazing to watch.
Rick
Rick
https://www.youtube.com/watch?v=FKXt25cm_0c&t=3s
For the bolt extraction... Removing the fender liner will gain some access with a better vantage point. I have removed numerous broken bolts on aluminum heads with a welder, most a couple threads deep. Aurthur's tip of building it up with tacks works. If using flux core, try to get a pick or brush in there to clean out the slag between tacks. Even though the weld wont stick to the aluminum, don't get it too hot with weld as it will melt out the threads.
If you have to remove the heads, efficiency can be gained with the stock head (even on a stock camshaft) by removing the large casting flash and a little bowl work and valve job. A mill for compression bump will also help across the board but will have a tradeoff with tune/octane. I would be more concerned about the low rpm/high load driving as a tow rig, especially with a stock or low duration cam due to the dynamic compression.
For your application, I like the BTR or Summit high lift out of the ones posted. They should keep the low end torque with a good midrange playing nice with a stock converter and be good on springs for lots of towing miles. I have the TSP 212/218 high lift in a 6.2L with a stock converter which I tow with occasionally. I noticed a minor torque lose below 2K but above that is all gains and rips 4000-6500. When I tow, I keep rpm 2500-3000 and it does well other than mpg.
zz454Chevelle67 (09-07-2021)
